Commit d919c4a5 authored by Sunny Wang's avatar Sunny Wang Committed by G Edhaya Chandran
uefi-sct/SctPkg: Allow SimpleTextOut SetMode to return EFI_UNSUPPORTED
REF: https://bugzilla.tianocore.org/show_bug.cgi?id=3738
The SimpleTestOut test cases don't allow SetMode to return
EFI_UNSUPPORTED, which doesn't comply with UEFI spec.
UEFI spec allows EFI_SIMPLE_TEXT_OUT_PROTOCOL.SetMode function to
return EFI_UNSUPPORTED for the condition below:
if the output devices support 80x50, that is defined to be mode 1.
All other text dimensions supported by the device will follow as
modes 2 and above. If an output device supports modes 2 and above,
but does not support 80x50, then querying for mode 1 will return
EFI_UNSUPPORTED.
Therefore, update the test cases to fix this issue.
Cc: G Edhaya Chandran <edhaya.chandran@arm.com>
Cc: Barton Gao <gaojie@byosoft.com.cn>
Cc: Carolyn Gjertsen <Carolyn.Gjertsen@amd.com>
Cc: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Cc: Samer El-Haj-Mahmoud <samer.el-haj-mahmoud@arm.com>
Signed-off-by: Sunny Wang's avatarSunny Wang <sunny.wang@arm.com>
Reviewed-by: G Edhaya Chandran's avatarG Edhaya Chandran <edhaya.chandran@arm.com>
parent 733a11dc
......@@ -2,15 +2,16 @@
Copyright 2006 - 2016 Unified EFI, Inc.<BR>
Copyright (c) 2010 - 2016, Intel Corporation. All rights reserved.<BR>
Copyright (c) 2022, ARM Limited. All rights reserved.<BR>
This program and the accompanying materials
are licensed and made available under the terms and conditions of the BSD License
which accompanies this distribution. The full text of the license may be found at
http://opensource.org/licenses/bsd-license.php
THE PROGRAM IS DISTRIBUTED UNDER THE BSD LICENSE ON AN "AS IS" BASIS,
WITHOUT WARRANTIES OR REPRESENTATIONS OF ANY KIND, EITHER EXPRESS OR IMPLIED.
......@@ -761,7 +762,11 @@ BBTestSetCursorPositionConformanceAutoTest (
Status = SimpleOut->SetMode (SimpleOut, Mode);
if (EFI_ERROR(Status)) {
AssertionType = EFI_TEST_ASSERTION_FAILED;
if (EFI_UNSUPPORTED == Status) {
AssertionType = EFI_TEST_ASSERTION_PASSED;
} else {
StandardLib->RecordAssertion (
StandardLib,
AssertionType,
......@@ -82,7 +83,7 @@ BBTestQueryModeConformanceAutoTest (
return Status;
SimpleOut = (EFI_SIMPLE_TEXT_OUT_PROTOCOL *)ClientInterface;
......@@ -759,7 +760,11 @@ BBTestSetCursorPositionConformanceAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -647,7 +648,11 @@ BBTestResetFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -3150,7 +3155,11 @@ BBTestSetModeFunctionManualTest (
// Return status check
} else {
} else {
......@@ -3177,7 +3186,6 @@ BBTestSetModeFunctionManualTest (
} else {
StandardLib,
AssertionType,
......@@ -3989,7 +3997,11 @@ BBTestSetAttributeFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -4547,7 +4559,11 @@ BBTestClearScreenFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -5062,7 +5078,11 @@ BBTestSetCursorPositionFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -5818,7 +5838,11 @@ BBTestEnableCursorFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -50,7 +51,7 @@ BBTestResetFunctionManualTest (
EFI_STANDARD_TEST_LIBRARY_PROTOCOL *StandardLib;
EFI_STATUS Status;
EFI_SIMPLE_TEXT_OUT_PROTOCOL *SimpleOut;
EFI_TEST_ASSERTION AssertionType;
EFI_SIMPLE_TEXT_OUTPUT_MODE ModeOrg, ModeExpected;
EFI_GRAPHICS_OUTPUT_PROTOCOL *GraphicsOutput;
......@@ -146,7 +147,7 @@ BBTestResetFunctionManualTest (
SctPrint (L"\n\rVGA Reset without extended verification start...\n\r");
WaitTimeOrKey (5);
// Prepare expected Mode after call Reset.
......@@ -455,7 +456,11 @@ BBTestResetFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -2738,7 +2743,11 @@ BBTestSetModeFunctionManualTest (
} else {
} else {
......@@ -3003,7 +3012,7 @@ BBTestSetModeFunctionAutoTest (
Status = RestoreMode (SimpleOut, &ModeOrg, StandardLib);
......@@ -3152,17 +3161,17 @@ BBTestSetAttributeFunctionManualTest (
for (IndexFore = 0; IndexFore < 16; IndexFore++) {
Attribute = EFI_TEXT_ATTR(IndexFore, IndexBack);
BackupMode (SimpleOut, &ModeExpected);
ModeExpected.Attribute = (INT32)Attribute;
Status = SimpleOut->SetAttribute (SimpleOut, Attribute);
// Wait for some time to change next background color
gtBS->Stall (100000);
......@@ -3206,7 +3215,7 @@ BBTestSetAttributeFunctionManualTest (
(UINTN)ModeExpected.Attribute,
(UINTN)ModeExpected.CursorVisible
Result = FALSE;
Result = FALSE;
......@@ -3388,7 +3397,11 @@ BBTestSetAttributeFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -3434,7 +3447,7 @@ BBTestSetAttributeFunctionAutoTest (
Status,
Attribute
Result = FALSE;
Result = FALSE;
continue;
......@@ -3464,12 +3477,12 @@ BBTestSetAttributeFunctionAutoTest (
Result = FALSE;
Result = FALSE;
if ( Result == TRUE ) {
StandardLib,
......@@ -3629,7 +3642,7 @@ BBTestClearScreenFunctionManualTest (
ModeExpected.CursorRow = 0;
ModeExpected.CursorColumn = 0;
// Clear screen with current background color
......@@ -3846,7 +3859,11 @@ BBTestClearScreenFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -3929,7 +3946,7 @@ BBTestClearScreenFunctionAutoTest (
Status
......@@ -4158,7 +4175,7 @@ BBTestSetCursorPositionFunctionManualTest (
Result = FALSE;
// Returned status check
......@@ -4177,7 +4194,7 @@ BBTestSetCursorPositionFunctionManualTest (
IndexRow
Result = FALSE;
// Wait for a little time
......@@ -4362,7 +4379,11 @@ BBTestSetCursorPositionFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -4447,7 +4468,7 @@ BBTestSetCursorPositionFunctionAutoTest (
Result = FALSE;
Result = FALSE;
......@@ -4467,7 +4488,7 @@ BBTestSetCursorPositionFunctionAutoTest (
IndexColumn,
IndexRow
Result = FALSE;
Result = FALSE;
......@@ -4501,7 +4522,7 @@ BBTestSetCursorPositionFunctionAutoTest (
Status
return Status;
......@@ -4931,7 +4952,7 @@ BBTestEnableCursorFunctionManualTest (
Status
return Status;
......@@ -5058,7 +5079,11 @@ BBTestEnableCursorFunctionAutoTest (
} else {
StandardLib,
AssertionType,
......@@ -5254,6 +5279,6 @@ BBTestEnableCursorFunctionAutoTest (
Status
return Status;
return Status;
} else {
StandardLib,
AssertionType,
EFI_STATUS Status;
WaitTimeOrKey (5);
} else {
StandardLib,
AssertionType,
} else {
} else {
......@@ -2986,7 +2995,11 @@ BBTestSetModeFunctionAutoTest (
} else {
} else {
......@@ -3003,7 +3016,7 @@ BBTestSetModeFunctionAutoTest (
......@@ -3152,17 +3165,17 @@ BBTestSetAttributeFunctionManualTest (
......@@ -3206,7 +3219,7 @@ BBTestSetAttributeFunctionManualTest (
Result = FALSE;
