Commit 5df202a4 authored by Umair Jameel Hashim's avatar Umair Jameel Hashim
Update README.md
parent a245f338
...@@ -11,42 +11,137 @@ There are three Evaluation Platforms being used as platform for the verification ...@@ -11,42 +11,137 @@ There are three Evaluation Platforms being used as platform for the verification
| Lenovo Leez | Leez-P710.xml | Leez-p710 | | Lenovo Leez | Leez-P710.xml | Leez-p710 |
| Pine 64 | RockPro64.xml | RockPro 64 | | Pine 64 | RockPro64.xml | RockPro 64 |
Note: The guide below has been extensively tested with the TB_RK3399ProD but is expected
to work with all of the above platforms.
## 1. Prepare Host machine
The following package installations and steps are required to be completed to build and install the firmware binaries.
sudo apt-get install -y cmake python3 python-is-python3 git gnupg bison flex
sudo apt-get install -y libssl-dev device-tree-compiler
# Configure git with your details
git config --global user.email "you@example.com"
git config --global user.name "Your Name"
# Install repo
# Option 1 - package manager
sudo apt-get install repo
## Option 2 - manual download
## curl https://storage.googleapis.com/git-repo-downloads/repo > /opt/repo
## chmod +x /opt/repo
## export PATH=$PATH:/opt
## 2. Clone the repositories
mkdir <New_Dir>
cd <New_Dir>
repo init -u https://gitlab.arm.com/systemready/firmware-build/rk3399-manifest -m TB-RK3399proD.xml
repo sync -j4 --no-clone-bundle
## 3. Get the Toolchains
If you dont have an aarch64-linux-gnu cross compiler already installed on your host machine, there are 2 ways of suppling the toolkits required to build the firmware and u-boot binaries.
* Option 1: Package install the cross-compilers on the host machine OS.
* Option 2: Use the toolchain installer thats provided by the makefile
## 1. Install repo ### Option 1: PREFERRED
Follow the instructions under the "Installing Repo" section
[here](https://source.android.com/source/downloading.html).
## 2. Get the source code
$ mkdir <New_Dir> sudo apt-get install gcc-aarch64-linux-gnu arm-none-eabi-gcc
$ cd <New_Dir> which aarch64-linux-gnu-gcc
$ repo init -u https://gitlab.arm.com/systemready/firmware-build/rk3399-manifest -m ${TARGET}.xml [-b ${BRANCH}]
$ repo sync -j4 --no-clone-bundle
Copy the path reported by the above command (excluding the tailing `bin/aarch64-linux-gnu-gcc`) and paste it after the command below:
## 3. Get the Aarch64 toolchain (optional)
$ cd <New_Dir>/build/ export AARCH64_PATH=
$ make -j2 toolchains
For example:
## 4. Build the target
$ make -j `nproc` $ which aarch64-linux-gnu-gcc
/usr/bin/aarch64-linux-gnu-gcc
$ export AARCH64_PATH=/usr
$ echo $AARCH64_PATH
/usr
## 5.Target Image Flashing Procedure ### Option 2: ALTERNATIVE (skip this if using option 1)
cd build/
make -j2 toolchains
The sequence will sync the atf(bl31), uboot(uboot.itb) to the local repo and ## 4. Build u-boot binaries for target
make the images for the selected target. Image flashing can be carried out ```
manually using the rktool, or the `make flash` target will use rkdeveloptool to cd build/
copy the images to a board in BOOTROM mode. make -j `nproc`
Amongst other things the above command will generate the following files of interest in the `../out/bin/u-boot/` directory:
Install Android Tool v2.71 u-boot.itb
Address Name Path : idbloader.img
0x0000 Miniloader — ../miniloader.bin ```
0x0000 GPT Partition Table — ../paramter_toybrick.txt Check the above by running:
0x0040 loader1 — ../idbloader.img
0x4000 loader2 — ../uboot.itb
ls -ltr ../out/bin/u-boot/
## 5. Building the FW binaries
cd ../rkbin
./tools/boot_merger ./RKBOOT/RK3399PROMINIALL.ini
The above command will generate the miniloader file: eg. `rk3399pro_loader_v1.25.126.bin`
## 6. Flashing the FW binaries and U-Boot
### 6-a: Preparing the host-machine
To succesgfully detect and flash the board the following packages are required to be installed on the host machine
sudo apt-get install pkg-config libudev-dev libusb-1.0-0-dev libusb-1.0
### 6-b: Put the board in MaskROM mode
1. Power-off the board
2. Keep the Maskrom button pressed for 10 seconds
3. Power on the board (either by long-pressing the power button OR plugging in the Power connector)
4. Release maskrom button after 5 seconds
5. The device should now be in Maskrom mode ready for flashing
6. Check if the board has entered MaskROM mode:
# Check if the following device is detected:
# Fuzhou Rockchip Electronics Company RK3399 in Mask ROM mode
lsusb
### 6-c: Writing the binaries to device
sudo ./tools/rkdeveloptool db rk3399pro_loader_v1.25.126.bin && sleep 2
sudo ./tools/rkdeveloptool wl 0x40 ../out/bin/u-boot/idbloader.img && sleep 2
sudo ./tools/rkdeveloptool wl 0x4000 ../out/bin/u-boot/u-boot.itb && sleep 2
sudo ./tools/rkdeveloptool rd
The TB_RK3399ProD board should restart and boot into u-boot
If you have a bootable storage device with LINUX installed connected to USB or installed in MMCslot the board should start booting the linux kernel.
Markdown is supported
