Commit 5b510ca2 authored by Grant Likely's avatar Grant Likely
Fix output directory of EDK2
Fix build problems of not finding binary images because the output
directory was incorrectly set.
Signed-off-by: Grant Likely's avatarGrant Likely <grant.likely@arm.com>
parent 912ef02d
...@@ -23,7 +23,7 @@ UBOOT_PATH := $(CURDIR)/u-boot ...@@ -23,7 +23,7 @@ UBOOT_PATH := $(CURDIR)/u-boot
# Give the option of building in a separate directory # Give the option of building in a separate directory
ifneq ($(BUILD_OUTPUT),) ifneq ($(BUILD_OUTPUT),)
__BUILD := $(realpath $(BUILD_OUTPUT)) __BUILD := $(realpath $(BUILD_OUTPUT))
EDK2_OUTPUT := $(__BUILD)/edk2 EDK2_OUTPUT := $(__BUILD)/edk2/Build
OPTEE_OUTPUT := $(__BUILD)/optee_os OPTEE_OUTPUT := $(__BUILD)/optee_os
OPTEE_EXTRA += O=$(OPTEE_OUTPUT) OPTEE_EXTRA += O=$(OPTEE_OUTPUT)
TFA_OUTPUT := $(__BUILD)/tfa TFA_OUTPUT := $(__BUILD)/tfa
...@@ -31,7 +31,7 @@ ifneq ($(BUILD_OUTPUT),) ...@@ -31,7 +31,7 @@ ifneq ($(BUILD_OUTPUT),)
UBOOT_OUTPUT := $(__BUILD)/u-boot UBOOT_OUTPUT := $(__BUILD)/u-boot
UBOOT_EXTRA += KBUILD_OUTPUT=$(UBOOT_OUTPUT) UBOOT_EXTRA += KBUILD_OUTPUT=$(UBOOT_OUTPUT)
else else
EDK2_OUTPUT := $(EDK2_PATH) EDK2_OUTPUT := $(CURDIR)/Build
OPTEE_OUTPUT := $(OPTEE_PATH)/out OPTEE_OUTPUT := $(OPTEE_PATH)/out
TFA_OUTPUT := $(TFA_PATH)/build TFA_OUTPUT := $(TFA_PATH)/build
UBOOT_OUTPUT := $(UBOOT_PATH) UBOOT_OUTPUT := $(UBOOT_PATH)
Supports Markdown
