The following section details the suggested coding guideline to be followed in the scmi tests project.
* This project follows Linux coding style in general
* Follow the 80 character width limit where ever possible
* Use snprintf instead of sprintf
* Avoid camel case throughout, but use small case
* Improve enum readability by using stacked coding style to allow inline comments
* Ensure copyright header is reproduce in all files
* This project follows Linux coding style in general.
* Follow the 80 character width limit where ever possible.
* Use snprintf instead of sprintf.
* Avoid camel case throughout, but use small case.
* Improve enum readability by using stacked coding style to allow inline comments.
* Ensure copyright header is reproduce in all files.
* Ensure file-scope variables and functions are defined with static keyword.
* Reduce stack usage by avoiding defining large local variables, instead go for static variables to use data segment storage.
* Header files to ensure have correct header guards
* Ensure Header files have correct header guards.
* Input parameters to functions that are immutable should be defined with const keyword.
* Codeblock / scope definitions start with opening braces { at the same line as the statement.
* All exported variables and functions to have arm_scmi_ prefix.
* Header includes to use angle brackets <my_header>
* Header includes to use angle brackets <my_header>.
* All pointer variables to be checked for null pointer de-reference before use.
* Prefer the use of compound literals to initialise struct type variables
* Prefer the use of compound literals to initialise struct type variables.
* Where ever the default external linkage is implied no need for explicit use of extern keyword.
* Avoid all whitespace errors |
\ No newline at end of file |
* Avoid all whitespace errors. |
